Old 01-28-2015, 12:53 PM   #1
BennyLava
Drives: 1987 Silverado
There is a TSB for the lower ball joints. The Toyota time is 5.5 hours. So $300 isn't a bad deal. The TSB is for both sides and I think the shop is quoting you just 1 side. Shops average about $60 per hour.
The TSB # is 0055-11
you can find the TSB here:
http://microimageonline.com/forums/s...TECH-TSB-FILES
scroll down to the bottom of the first post and you will see a link to USA TSB's. Then another window will pop up and scroll towards the bottom. Look for TSB0055-11
It will show you how to replace it, what the new part number is and if your car will fall under the specified repair.
So what are those? IIRC, TSB stands for toyota service bulletin. Thank you for the info, but how can that help me? I'm assuming that its not something that toyota will fix for free. Just trying to understand the meaning of your post.
Old 01-28-2015, 05:18 PM   #2
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Yea, you are correct. It is called a Toyota Service Bulletin. What Illusion said. They are issues that happen often that Toyota has made a standard fix for or a new updated part.
I figured this would have answered all your questions if you had clicked on the link and actually looked at the TSB.
*TSB addresses the complaint
*shows how many hours it takes a mechanic to replace
*What VIN number the change was made
*Old part number and New updated part number
*Then it actually shows you HOW to replace the part yourself if you wanted to try and not pay a shop to do it. It even tells you what size sockets are needed and torque specs
That is if you actually opened up the TSB and read it.
-Derrick-
Old 02-03-2015, 03:29 PM   #3
BennyLava
I opened it and saw what it was and then saved it on my computer for later. I'll keep that as long as I have the car as its valuable info.
I'm assuming that the toyota dealerships upload all repairs to a database that Toyota can see? That way they know what to make a TSB for.
And I'm also assuming that pretty much all automakers have the same system? So for ford it would be FSB, and Gm would be GMSB? Its nice to know these things.
Old 02-07-2015, 08:29 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Very well said and true but not to general public you need online access for anything more that the TSB gives in description but yes it will specify exactly how to fix or resolve the issue.
Also keep in mind if we all follow the way it should be done " by the book " we would make no money as flat rate.
There is 3 ways to fix a car
The right way , the flat rate way and the wrong way lol
If the public only really have know how it works they would never take a car into any shop .
In my opinion find a place with guys that are based on hourly pay not flat rate.
I for one hate flat rate!
A day out with mechanic went wrong- Right arm problem talhahs DIY / Maintenance / Service 6 05-17-2013 05:20 PM
Toyota Dealership Mechanic Scratched one Rim YodaBird Third Gen Yaris General Discussion 20 05-17-2013 04:03 PM
Beware of the "simple" brake job tasks Yarflana DIY / Maintenance / Service 7 03-18-2013 02:26 PM
Any one in Indianapolis know of a good job for a computer tech? CtrlAltDefeat Great Lakes 15 10-28-2009 01:16 AM
