Old 01-28-2015, 10:12 PM   #1
Checking the fluid on a hill would effect the level and fluid couldn't cause what you are seeing.
The switch is mounted to the front of the transmission, which is located just below the air intake box at the very front on the driver's side. If you pop the hood and look between the radiator and the engine you can get a view of it. To really get at it you need to remove the air intake assembly. The switch is circled in the image below.
The object which you hit may have bent the arm that actuates the switch and after a bunch times moving it, it may have come loose:
Old 01-28-2015, 10:14 PM   #2
Christine88
Drives: 2009 Yaris
Attachment 54884
Thanks for the photo. Is that thing expensive?
Christine88 is offline   Reply With Quote
Old 01-28-2015, 10:26 PM   #3
It's about $200 online or $300 from a Toyota dealer. (84540-46010)
If you are lucky though you will find that something is slightly bent or loose.
Old 01-28-2015, 10:28 PM   #4
Christine88
Drives: 2009 Yaris
Thank you I'll take a look at it tomorrow.
Old 01-29-2015, 07:48 AM   #5
Christine88
Drives: 2009 Yaris
Actually it's a 2011. I had a 2009 but traded it in for this one. Would it be the same part?
FS: Various Parts from a 2009 Yaris Hatchback Freestylin Items for Sale by private party 17 02-24-2016 09:36 PM
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
2009 Yaris LB 5-speed MGargano Cars for Sale by private party 9 02-04-2012 01:01 AM
