Old 01-29-2015, 06:59 PM   #1
Originally Posted by Shinare View Post
Scott,
Sorry it took so long to reply, if I roll my windo down about an inch the windo does sound like its ratteling around a bunch, kind of like if it were loose in something. Do I need to tak emy door card off and get inside to see anything specific? Is there a way to fix this easily, like tighten something?
Thanks again Scott, you are one of the reasons this place is so great! :)
You will need to pull the door card. once you do you can access the metal frame that supports the window through the access holes. Also check that the bolts that mount the window regulator to the inside of the door are tight.
DIY - OEM Power Window Conversion CTScott DIY / Maintenance / Service 29 10-27-2024 11:02 PM
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 10:03 AM
Power window noise birdman DIY / Maintenance / Service 10 09-01-2012 12:11 PM
rubber rubbing noise from front right of car Golddeenoh DIY / Maintenance / Service 5 06-07-2012 06:14 PM
Rear window sedan crackling noise. krolos General Yaris / Vitz Discussion 3 04-09-2011 12:39 AM
