Old 01-31-2015, 06:06 PM   #1
virgilio992
Drives: yaris now 1.0 12v
Ok i checked out and it DOES the noise revving in neutral! What can i do to fix this out? At least i think we can exclude a gearbox problem!
virgilio992 is offline   Reply With Quote
Old 01-31-2015, 06:30 PM   #2
That's good that it is not the gearbox. It is likely exhaust related, so now it is a matter of figuring out where it leaks when hot. You can try shining a light while someone else revs the car (once it is hot) or you can bring it to a shop where they can put it up on a lift to look from under.
Old 01-31-2015, 06:44 PM   #3
virgilio992
Thank you so much! I will try to shine a light with the help of a buddy of mine... unfortunately in italy it costs 50$ just to lift up your car..... i hope that the it would be cheap to solve it out
Old 01-31-2015, 08:30 PM   #4
If your remove the aluminum heat shield from the exhaust manifold you will be able so see better.
Out of curiosity, in what part of Italy are you located?
Old 02-01-2015, 06:26 AM   #5
virgilio992
I'll see ASAP!
i'm actually here:
Old 02-01-2015, 07:21 AM   #6
I'll see ASAP!
i'm actually here:
Ah, very good. I have never been that far south on the eastern side of Italy, except passing by there on a cruise ship.
Old 02-01-2015, 09:22 AM   #7
virgilio992
you should, the place is beautiful except for people's bad actitude
