Old 02-01-2015, 08:35 AM   #1
sebastianroher
Drives: 2009 Toyota Yaris Hatchback
How do I change the fuel filter? I was told it wasn't supposed to be changed as its in tank..
sebastianroher is offline   Reply With Quote
Old 02-01-2015, 09:00 AM   #2
It is in the tank and to get to it you have to remove the bottom of the back seat to get to the access hole. Just because it is in the tank does not mean that it never needs to be replaced. If low quality or contaminated fuel was used in the car, the filter can get plugged pretty easily.
Old 02-01-2015, 11:31 AM   #3
bronsin
bronsin's Avatar
Its not an item that is changed to a schedule. It is serviced only when theres a problem. Unless there is a problem it will avail you of nothing to change it.
I have heard the FF isn't available separately. It only comes with a new fuel pump.
push start vs electric start? yaris2010RS General Yaris / Vitz Discussion 18 04-07-2010 02:20 PM
Yaris 2008 does not start sberdina DIY / Maintenance / Service 8 04-06-2010 02:03 PM
Toyota Smart Start Blue Yaris General Yaris / Vitz Discussion 0 04-02-2010 07:48 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
Tip Start machine1 General Yaris / Vitz Discussion 12 02-19-2007 03:08 AM
