Old 02-02-2015, 12:05 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
If there was a sensor problem, you would have an associated code. The computer won't give you ignition coil codes for a crank sensor problem.
Sent from my iPod Touch
Old 02-02-2015, 06:13 AM   #2
You have to look at his other three threads and a pile of PMs. Besides the codes he is seeing now, his compression measures bad on cylinders 2 and 3.
Also, P0351-P0354 can be caused by the Oil control valve not working due to being plugged up. That is the round device mounted next the alternator. It also has a fine mesh filter mounted into the block below it.
push start vs electric start? yaris2010RS General Yaris / Vitz Discussion 18 04-07-2010 02:20 PM
Yaris 2008 does not start sberdina DIY / Maintenance / Service 8 04-06-2010 02:03 PM
Toyota Smart Start Blue Yaris General Yaris / Vitz Discussion 0 04-02-2010 07:48 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
Tip Start machine1 General Yaris / Vitz Discussion 12 02-19-2007 03:08 AM
