Old 02-02-2015, 09:46 PM   #1
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
How to make a duplicate transponder key?
No need for master key to program new keys but u need to reprogram ECU by obtaining a 6 digit code directly from Toyota this will wipe the ECU old security and reprogram with new with and new cut keys don't know why they are charging u so much tho it's about a 15 min procedure with tech stream online with Toyota plus cost of keys and remote.
Old 02-02-2015, 09:55 PM   #2
Are you sure about that? According to the service manual, with no master keys in possession the transponder key ECU has to be replaced to add new keys. I know that when you buy a new Toyota you get a little metal tag with the keys that you are told "not to lose". My understanding is that code is just for cutting the physical key - It has nothing to do with resetting the transponder.
Old 02-03-2015, 05:50 AM   #3
ndzzb
Drives: 2011 toyota yaris
Hi wolfman,
Thanks for your useful information. How much will it cost generally? Dealership told me they have to order a new key from toyota for $165, together will other costs, almost $400. but the key is much expensive than ebay. could I buy a new key myself?
ndzzb is offline   Reply With Quote
Deactivating the lost key. vicky DIY / Maintenance / Service 6 11-14-2014 12:19 PM
I lost my master keyless entry key, need suggestions.... Frankd1 DIY / Maintenance / Service 19 12-01-2010 11:13 PM
Replacement key / keyless entry mcduck DIY / Maintenance / Service 4 08-30-2010 06:52 PM
Need remote key fraenx DIY / Maintenance / Service 1 06-26-2009 07:29 PM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
