Old 02-07-2015, 03:10 PM   #1
MUSKOKA800
MUSKOKA800's Avatar
After installing the TRD suspension components I had a performance alignment done and the sedan's LR was off spec however not worth concern according to the shop owner/technician. Shims can be added behind the brakes to correct toe &/or camber issues. New rear beam not required unless damaged.
Old 02-07-2015, 09:41 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
As far as I know, there are no proper shims available for the Yaris. The "EZ shims" are plastic, which is not an acceptable material. Plastic "cold-creeps" which means it very slowly squirts out of the gap it is filling causing your bolts to lose their torque, and potentially fall out. Common place to see this is plastic drainplug washers. If the EZ Shims were metal, they would be a great option. Using metal washers, or shims that do not fill the entire gap reduces the amount of surface area for and can cause cracks, loss of clamping force etc.
All that is left is custom shims, or replacing the axle beam.
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
My black 2008 Yaris S sedan at sunset NOT 56K SAFE *PICS* MPC Motorsports Photo-Video-Media Gallery 26 05-24-2009 10:32 AM
