Old 02-17-2015, 03:07 PM   #1
Thebigwicks
Drives: 2008 lowered yaris on 17's
Are there anything missing or wrong on these?
Thebigwicks is offline   Reply With Quote
Old 02-17-2015, 11:51 PM   #2
juicyjosh
juicyjosh's Avatar
Drives: 2012 Yaris SE MT
Nothing at all is wrong with these coil overs.
As stated above, they were only on the Yaris for 14 months for about 6800 miles, originally installed and removed by yours truly. I've provided as much detail as to their history as possible so the new owner can buy with confidence.
Everything in the first 8 pictures of this thread is included. The TEIN STREET ADVANCE coil overs use the following parts off your stock Yaris:
For the fronts, the TEINs use the stock bump stops (cut in half), the stock spring top plate to hold the spring (secured by the gold nut), then place the big stock rubber bushing/mount on top and bolt the coil over on the car. (The gold nut and big rubber bushing/mount are pictured above.) The stock Yaris bolt-on hardware (i.e. bolts and washers) are used at the top of the struts/shocks at all 4 corners.
I've packaged the entire set of TEIN STREET ADVANCE coil overs at the same height settings as I had on my Yaris (pictured, not included), which is maximum low in the front, and room to play in the rear (either go another inch or so lower, or raise it up about 3 inches), so the buyer will already know how her or his car will look with the STREET ADVANCEs out-of-the-box, based on the pics.
juicyjosh is offline   Reply With Quote
Tein Street Basis Coilover Install - 2007 Canadian Yaris Sedan NCP93 Stock sheekeebut Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-13-2014 07:39 AM
Tein Street Basis Coilover Install - 2007 Yaris Sedan NCP93 Stock sheekeebut Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-13-2014 12:32 AM
FS: tein basic coilovers $500 shipped thebarber Items for Sale by private party 24 09-24-2013 03:59 PM
FS: FL barely used tein flex coilovers '06-'11 Shoodoggy Items for Sale by private party 38 06-09-2013 11:42 PM
More pics of Tein LB? Walter Cosmetic Modifications (Exterior/Interior) 17 02-07-2007 04:14 AM
