#163 |
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015 Join Date: Mar 2012
Here is the how to for ap900c in Danish but it is simple.
http://www.asmarketing.dk/f/f1/AP900...iesel-2009.pdf You Will also need the wire tharness no 190-5002220 http://www.autobutik.sk/product-21529-190-5002220/ |
#164 | |
![]() ![]() Drives: 2012 Yaris TR 1.33 VVT-i Man Join Date: Nov 2014
CTScott, I've received your kit (thank you). I've tried to install that today but got stuck when tried to remove the airbag. The steering wheel of my Yaris is exactly the same like one on the pictures above but I couldn't get access to the clips. The steering wheel back cover has only one hole (in the middle). Any idea how do I unclip the remaining two? thanks Had a look athe post 55 (thanks Stuart_f) & hopefully I will be able to manage to do this way Last edited by karloslatynos; 02-11-2015 at 06:42 AM. |
#165 |
![]() Drives: Yaris 2009 1.3 sol 100HP Join Date: Feb 2015
Hello C Scott,
I have the 2009 yaris Sol 100HP MMT transmission I will appreciate your help. could you please check if it possible to install the cruise control on my car? |
#166 |
Drives: Toyota Yaris Icon Hybrid 2014 Join Date: Sep 2014
Big thanks to C Scott.
Fitted mine this week and it works a treat. Reasonable easy to install except for one stubborn spring clip> Thanks again. |
#167 |
Finally got my cruise control kit installed and tested on my Yaris III. Works perfect and I find it very usefull.
The installation process is very simple exept removing the airbag. It was absolutely nightmare! The access to the side clips is very limited. As somebody said in the post 55 the side clips required to be lifted. I couldn't do that with the clip located near to stalk control. I even removed two screws holding the audio panel on the steering wheel to make more room to access that bloody clip. Finally I've managed to completely pull out the clip from it nest and the airbag popped out. What a relief that was.... I was able to start breathing again. The rest of the installation process (including final push the airbag to the steering wheel) took less than 5 min. I strongly recommend to all Yaris users to get the cruise control from CTScott. The price is reasonable and as I mentioned before its worth every penny. |
#168 |
I have tested the cruise control on a long trip (Birmingham UK - Brussells BEL) & I am so impressed with it. Apart of driving comfort it also has reduced the fuel comsumption big time.
Someone said to me that using cruise control will increase breake pads usage. How does actually work? Does cruise control use breaks to keep constant speed while driving downhill? |
#169 |
![]() Drives: Toyota Yaris T-Sport Join Date: Feb 2015
Heyy, im new here, i have a yaris 1,8 vvt-i Ts. Do any of you know if i can get the original toyota cruise control to fit in my car??
#170 |
ps, my Ts is from 2007.
#171 | |
Cruise control does not have the ability to actively brake the car. It can only do so with engine braking.
#172 | |
Unfortunately there is not an OEM solution for your Yaris.
#173 |
![]() Drives: Yaris 1.33; Edition 2014; Join Date: May 2015
Hi there.
I have installed the switch, the Cruise Control works with no problems, BUT the lights in the dash are not active. Could it be that there a no bulbs installed? I think this should be LED or not? Someone have an idea? One hint for dismounting the Airbag. The first spring is simple, just press a screwdriver into the hole on the bottom. (as described here in the thread) The second spring comes of through the side-panel, which you have to remove to see the spring and later install the switch (also as described here in the thread) The third spring seems complicated but as the holes are elongated you only have to slide the hole Airbag-Unit a little to the otherside and the unit comes off. Last edited by haunter1982; 05-18-2015 at 08:58 AM. |
#174 |
Some of the European instrument clusters are not equipped with the indicator.
#175 |
Damn. I can see the sign but it doesnt light up. Are there bulbs or LED's in the Instruments?
#176 |
LEDs
#177 |
![]() Drives: Yaris 2012 Join Date: Feb 2013
Haunter
I'm from Slovenia, and have same problem. CC from scot works flawless, but no light indication. I tried to check if there are some leds, but gaguge needle is hard to remove or i don't now a right way to remove to check if there are missing two leds. If there are not any leds, maybe if solder up some leds an try? |
#178 |
I don't think that the LEDs would work if you added them. From what I have found with the software in the clusters, it doesn't drive the features not present.
#179 |
Is there a way to activate it through techstream?
#180 |
No
| Tags |
| cruise control. 2012 |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 12:59 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
