2ZR swap. DO IT! Ask how!
The Blitz kit has the advantage of being mostly plug-and-play, with the exception of the wire harness. You don't need bigger injectors unless you plan on getting a bigger throttle body or intake, and you don't need engine management unless you're going to try and squeeze every ounce of performance from the system. Yes, the kit is more expensive than a basic turbo kit, but you need a LOT of support (parts and personnel) to make a bare bones kit work properly.
Plan on $5k for either option, more if someone else will do the labor. I'm not sure if the Blitz xB kit is bolt-on for the Echo, but it may be. |
#2 | |
![]() Drives: 2001 Toyota Echo Red Sedan Join Date: Jan 2015
| Tags |
| echo, kit, turbo |
| Just went from Echo RS to Yaris RS, Not really an upgrade.... | Thor_e | Performance Modifications | 9 | 08-27-2013 01:16 PM |
| Worst Cars of the 2000s (#4. Echo) | MadMax | General Yaris / Vitz Discussion | 34 | 11-12-2009 10:41 AM |
| Toyota Echo and Yaris TWM Short Shifter Sale! | TWM Performance | TWM Performance | 3 | 08-24-2009 10:50 AM |
| Yaris and Echo short shifters sale, $30 off! | TWM Performance | TWM Performance | 8 | 11-17-2008 02:23 PM |
| Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? | ceboyd | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-08-2006 02:13 PM |
