Old 02-27-2015, 04:27 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
I'm not sure if straight line is affected by camber. Mine was out of spec, and I had camber shims added to get 0 camber at the front.
Old 02-27-2015, 04:51 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
Yes, cross-camber or cross-caster (difference side to side), can cause the vehicle to lead left or right. 0.5° different is usually the max allowed.
Cheers.
No factory rear alignment gear? bad DIY / Maintenance / Service 6 01-28-2015 12:21 PM
understeer DOMAV General Yaris / Vitz Discussion 31 09-30-2009 07:01 AM
Should i go get a "Free" wheel alignment Yawesh General Yaris / Vitz Discussion 22 09-14-2009 09:44 AM
Wheel Alignment Data Asif Kazani Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-22-2007 12:48 AM
