Old 02-28-2015, 05:04 PM   #1
2005rs
Drives: 2005 Echo Rs
I had my echo to the same garage three times in a row to correct alignment after redoing the front struts. One of the mechanics suggested rotating the tires. The manager wanted to 'adjust the alignment out of spec to make it work right'. I rotated the tires and it worked! Don't know why, but it did
2005rs is offline   Reply With Quote
Old 03-02-2015, 12:43 AM   #2
CoryM
Drives: 2009 5-door, 5-speed
Tires can definitely cause leads/pulls. It's possible that now your tire lead is going the opposite direction of your car's lead, and cancelling it out. If a car comes into my shop with no impact-damage, I always rotate the front tires left to right first to diagnose if it is a tire-lead, or an alignment-lead.
Cheers.
No factory rear alignment gear? bad DIY / Maintenance / Service 6 01-28-2015 12:21 PM
understeer DOMAV General Yaris / Vitz Discussion 31 09-30-2009 07:01 AM
Should i go get a "Free" wheel alignment Yawesh General Yaris / Vitz Discussion 22 09-14-2009 09:44 AM
Wheel Alignment Data Asif Kazani Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-22-2007 12:48 AM
