![]() Drives: 2014 yaris 5dr Join Date: Feb 2015
I had a problem like that with a dodge caravan. I put the van up on jackstands, started it and put it in drive. I read the voltage off the sensor with a voltmeter. Checked for the voltage at the ecm and had it there. Turned out to be a bad ground rather than the sensor.
#2 | |
#3 | |
I found a bad ground lead off of the transmission control module. The lead had been back probed and the hole had never been sealed. The wire corroded through in two or three places along its length. Hard to find but cheap to repair. |
| Yaris sales hit new low... | Kal-El | Third Gen Yaris General Discussion | 131 | 10-18-2025 11:59 AM |
| ABS and "!" lights are ON again! | onizuka | Canada | 457 | 04-28-2023 09:40 AM |
| P0715 - Input/Turbine Speed Sensor | furinji.saiga | DIY / Maintenance / Service | 7 | 02-02-2015 06:07 AM |
| Speed signal wire | drecian | DIY / Maintenance / Service | 12 | 06-14-2010 07:19 PM |
