The 1NZ is a naturally noisy engine. Mine has always had taps and rattles which used to lead me to believe I had valve and chain issues. That is until I learned on this forum that these noises are normal. Had gotten used to the silence of a timing belt.
#2 | |
![]() Drives: 2014 yaris 5dr Join Date: Feb 2015
The head bolts for the Echo require a double hex bit. It looks like a T-5 Torx bit but is not. Snap-On sells the proper bit (8 mm, I think but it's best to check).
If you choose to do the head get the proper tool. I am assuming the Yaris uses the same head bolts. |
#4 | |
Dom's?
| Head/ TB / Spacers / Turbo and Other thing | xbgod | Items for Sale by private party | 33 | 11-07-2010 11:52 PM |
| Another 2010 head gasket oil leak found ... | Hershey | General Yaris / Vitz Discussion | 4 | 10-20-2010 12:18 AM |
| GO FOR IT ? Trade 2010 3 door ( W/oil leaking head gasket ) for 2010 sedan | Hershey | New YARIS Purchase Forum | 9 | 10-10-2010 01:06 AM |
| Changing LED's In Projector Head Lights | whooppee777 | Cosmetic Modifications (Exterior/Interior) | 16 | 03-01-2009 02:07 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
