Old 03-11-2015, 08:36 PM   #1
KingForADay
KingForADay's Avatar
Drives: 2013 5 dr. Liftback Yaris LE
It is a separate little tiny bulb. There are a few threads on here with pictures of what they look like and how to change them on a 2nd gen Yaris. For your 3rd gen it would be basically the same. There are LED replacements for them and I believe there is a thread on here with LED bulb info that also lists them.
Thanks very much for the info CTScott. I'm not mechanically inclined so what do you estimate would be a reasonable charge for a mechanic to replace all 3 bulbs with LED lights that I would supply?
KingForADay is offline   Reply With Quote
Old 03-11-2015, 09:17 PM   #2
It should only take one a couple of minutes, but they would likely hit you with a minimum charge (30 minutes or so).
Old 03-11-2015, 10:27 PM   #3
KingForADay
Great, thanks so much for the info!
climate bulb replace
The electronic climate control displays mrbond In Car Entertainment + Electronics (audio / video / alarm) 43 04-18-2021 03:34 AM
Digital Gauges, Auto Climate control, Manu-matic shifter computerlove87 Cosmetic Modifications (Exterior/Interior) 21 12-02-2012 11:55 PM
Yaris 09 climate control lights alt_k1ll3r DIY / Maintenance / Service 2 11-11-2008 10:19 PM
Bulbs For Behind The 3 Climate Control Knobs razzorjet2 DIY / Maintenance / Service 2 04-06-2007 10:41 AM
