Old 03-14-2015, 10:07 AM   #1
nkaufman
Drives: Yaris
HIGHLY unusual! You can check the belt yourself. #1 is it squealing during startup? If not thats good. Squealing indicated a loose belt.
#2 check the mult-ribed surface on the inner side of the belt. Without the engine running feel the inner side of the belt with your fingers. There are about 5 mini V's on it. As long as these are intact and not hanging in shreads or little bits missing from the tiny V's belt is good.
If the dealer changes ANYTHING tell them you want the old parts!
Good luck and tell us what happens!
Have not heard any squealing etc and have not done anything about it so far. Looks good. Was really thinking that the belt would make some noise before dying, wouldn't it?
nkaufman is offline   Reply With Quote
Old 03-14-2015, 11:09 AM   #2
bronsin
bronsin's Avatar
Not really no. A squealing belt is a loose belt. Tighten it to specs and the squealing should stop. A BAD belt will have the mini V's on the pulley side of the belt (not the smooth side) hanging in shreds and disintegrating.
I would say even a squealing belt as long as it drives the accessories is OK and isn't flapping loose. As long as the mini V's aren't damaged. An overtightened belt can damage the water pump and other driven accessories.
My wifes 05 Camry with 120k on it has the original belt. I can see nothing wrong with it. I check the mini v's every oil change. (twice a year) When the mini v's get damaged....off to Toyota for a new one!
My brother in law changed the wp a couple years ago and when he did he changed the belt tensioner it was bad. Yaris has no bt.
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
drive belt neal3d DIY / Maintenance / Service 0 06-07-2014 12:11 PM
seat belt chime disable? Lewis DIY / Maintenance / Service 19 05-25-2012 04:36 PM
HELP!? HORRIBLE drive home during first REAL Snow in Michigan, paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 12-11-2009 08:07 PM
HELP!? HORRIBLE drive home during first REAL Snow in Michigan paulyd0021 General Yaris / Vitz Discussion 32 12-10-2009 01:23 PM
