Old 03-22-2015, 07:07 PM   #1
jmandawg
Drives: 2007 Yaris
Sorry it took so long, had to go over to my brothers place to use his guages.
Here is an image of the reading while the AC was running. It was 77F outside at the time. I know there is only one fan for the radiator and the condensor, but does it have a hi and low speed? It sounded like it was running at high speed for like 10-20 seconds and then it seemed to be running at low speed the rest of the time. Maybe it's supposed to be running at high the entire time.
Also there seems to be some green dye in the system already as it sprayed everywhere when we disconnected the hose.
jmandawg is offline   Reply With Quote
Old 09-03-2023, 07:02 AM   #2
rayfloyd170
Drives: Yaris 2016 1.3 Manual
@jmandawg
i am also thinking about bent fins in my condenser. i will try to clean it also this weekend with coil foam spray and water.
one guy told me to use a toothpick to re-align the fins to the best i can to avoid restricted airflow.
rayfloyd170 is offline   Reply With Quote
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
Idle or Power Problem? duendeverde DIY / Maintenance / Service 11 12-13-2014 03:08 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
Wheels slipping when hard lock turning - dealer says this is normal? eskiepeskie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-08-2012 08:49 PM
Turning on the a/c caineroad Fuel Economy Forum 31 07-29-2011 11:07 AM
