Old 03-23-2015, 06:28 PM   #1
jmandawg
Drives: 2007 Yaris
CTScott, I test the resistence:
12.09K between the grey and black wires
7.26K between the yellow and black wires
Does this mean it's bad? Also it looks like changing it requires a full discharge/evac/recharge?
jmandawg is offline   Reply With Quote
Old 03-23-2015, 08:38 PM   #2
Those are fine. The next step is to check the sensor's actual output while the system is on.
To do that you need to measure the following. To do so you need to poke something tiny and sharp through the wire insulation and into the wire (I like to use a small sewing needle):
Voltage of the yellow wire to ground (should be 5 Volts)
Voltage of the grey wire to ground (should be between 0.76 volts and 4.74 volts)
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
Idle or Power Problem? duendeverde DIY / Maintenance / Service 11 12-13-2014 03:08 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
Wheels slipping when hard lock turning - dealer says this is normal? eskiepeskie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-08-2012 08:49 PM
Turning on the a/c caineroad Fuel Economy Forum 31 07-29-2011 11:07 AM
