Old 04-12-2015, 08:27 PM   #1
Originally Posted by Maranda View Post
Is there a way to know if only the harness are to be changed, or the hubs?
I want to take advantage of the nice weather to check it tomorrow.
I did a scan, and in my case, I have the error codes for the 2 abs in the rear.
You can easily tell which needs to be replaced by disconnecting the connector from the sensor in the hub. If the sensor's pins are intact you just have to replace the cable. If the sensor's pins are severely corroded, then the sensor will likely need to be replaced.
Old 10-23-2015, 05:25 PM   #2
Edmontonian78
You can take some sewing needles and use them to check for continuity on the wiring harness with a multi meter. On the 2007 sedan model if you push down the back seat so you can see the inside of your trunk; the connector for the speed sensor wire is right inside the plastic trim and you just need to remove a plastic pin that holds it in place.
Edmontonian78 is offline   Reply With Quote
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
Trouble putting 3rd brake light after rear speaker install..... YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 5 12-05-2008 03:10 AM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Removing third brake light lightyearsgirl DIY / Maintenance / Service 8 08-06-2006 11:26 AM
