![]() Drives: 08 yaris Join Date: Apr 2013
Fuel Guage help
I saw a while back a post regarding stuck fuel Guage and cleaning the contacts on the sender. Is there a step by step anywhere? And how well does it work? What's the best way to test after?
Thx 2008 yaris 120k |
If you are going to go through the hassle of pulling the fuel sender (remove rear seat, open floor hatch, remove gas tank top), you should probably just plan to replace it.
You can try using a good fuel system cleanser first, as that may help.
OK can I just replace the sender and where do I get that.
You typically have to purchase an entire fuel sender unit to get one, as Toyota doesn't sell them separately. If you are interested I actually have just the fuel level sender on hand from a fuel sender assembly that I used for calibrating fuel pressure regulators. I could do $25 shipped on it.
I'm going to pull it this weekend to try and clean it, the car did sit for 6 months. If that doesn't do it I pm you.
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 04:07 PM |
| Do any Yaris owners use premium gas ? | DanMC | Third Gen Yaris General Discussion | 38 | 11-06-2013 11:36 AM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 04:34 AM |
| fuel guage issues | bonusjonas | DIY / Maintenance / Service | 4 | 12-07-2011 09:52 AM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
