Old 04-24-2015, 09:25 AM   #1
nortonfb
Drives: 2007
Centric published a TSB about pulsation. In which they stated the warpage is usually not
the problem with a pulse. They gave a number of other reasons.
Rotors are cheap and are cheap insurance.
Not like the Brembo on the bike, when I missed changing the pads.
nortonfb is offline   Reply With Quote
Old 04-24-2015, 11:03 AM   #2
tmontague
tmontague's Avatar
the issue I had wasn't due to warpage, it was too little metal caused excess heat buildup which burnt pads on rotor. The pad residue would grab the pad more causing the pulsating
Old 04-24-2015, 05:40 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
I'll check that out when i have my set installed. I mean at <100$ for 2 rotors and pads included. I can't even get a single OEM rotor for that price...
