Old 04-26-2015, 09:33 AM   #1
scod4025
Drives: 12 LE 5d HB 1nz-fe Automatic
Hello and welcome to YW
I would tend to lean towards the Fuel Filter having issues such as being installed backwards or the wrong one or possible fuel line not fully secured to the filter causing an air leak
You didn't mention this but do you have a rough idle after start? If you have a rough run after start up for a little bit might also be the injectors
scod4025 is offline   Reply With Quote
Old 04-27-2015, 05:13 AM   #2
asimaleem
Drives: Vitz
Thanks for the quick response.
By "rough idle after start" , i assume you meant that does car vibrate immediately after engine is switched on ? if so ,the answer is 'not really' apart from regular minor vibration that is always generated by Vitz engine as its 3 cylinder 1.0 L
One more thing: After stalling ,car starts with a very long cranking on first and sometimes on the second attempt . This cranking duration remains the same even if the race paddled is fully pressed during cranking compared to when the racing paddle is not pressed at all during cranking
Do you still suspect fuel filter and injectors?
asimaleem is offline   Reply With Quote
Vitz 1.3L 2006 Shift all the gears at low RPM ahsan DIY / Maintenance / Service 0 05-30-2013 01:48 AM
Low RPM when Idle Betrivent DIY / Maintenance / Service 12 03-03-2013 06:55 PM
2006 toyota vitz low trackling PROBLEM Krazzyd General Yaris / Vitz Discussion 5 10-11-2012 08:11 AM
MMT Semi-Automatic Gearbox problem on 2006 Yaris 1.0 Sol davidv General Yaris / Vitz Discussion 3 10-12-2010 02:02 PM
Best MOD for midrange to lower rpm gain. Neen a little more low end grunt. dtbrown Performance Modifications 13 03-29-2009 04:35 PM
