Old 05-02-2015, 04:32 PM   #1
nookandcrannycar
CA wont like diesels because of their pollution. And in any case, the long term trend in gas vs diesel prices is diesel is more expensive. Like hybrids, diesels don't make sense economically. Bottom line diesels cost more to own, same as hybrids.
. In addition, well taken care of gasoline engines are now closer to the lifespan of diesels, mileage wise...so that advantage is nolt what it once was.
Old 05-03-2015, 06:55 AM   #2
bronsin
bronsin's Avatar
Yes as your experience and that of others proves! I think there are two reasons for this. One FI has eliminated the rich running at idle of engines and allowed for the uniform carburation of them at all speeds. Quite a bit of wear takes place in a carbureted engine at idle. Also, the elimination of lead in fuel makes oil change intervals longer and increases spark plug life almost indefinitely.
Change the oil and air filters in modern gas engines, especially Honda and Toyota gas engines, and they will easily outlast the life of the rest of the car.
Given the particulate pollution and NOx from diesels I see no reason to own them, for the consumer.
