Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Might as well post up my setup...
Engine- AEM cold air intake, DC header, Magnaflow custom 2" cat--back, NST crank pulley, Simota oil catch can. Suspension- Tein Basis coilovers(testing purposes only, Normally TRD springs and Tokico HP), Whiteline control arm bushings, TRD strut top mounts, TRD rear sway bar, Eibac crash bolts. Brakes- Stoptech slotted rotors, MI brake lines, Hawk HP pads Enkei RPF1 15x7 + Dunlop Z2 205/50R15
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 05-21-2015 at 12:02 AM. |
#2 | |
![]() ![]() Drives: 07 Yaris Join Date: Sep 2012
Did you do a 2zr swap at one point?
How was it? And what did you do for mounts? Quote:
#3 | |
09 Yaris S 85 Corolla GTS |
#4 | |
iQ innovator & researcher
Drives: 2012 iQ Join Date: Mar 2016
Which Whiteline Control Arm bushings are you using in the Yaris control arms? Are you using the CASTER + or just the normal? |
| 1NZ-FE All Motor Build | burned | Performance Modifications | 19 | 10-24-2014 11:56 AM |
| Carbon build up in the throttle body | Sedan | DIY / Maintenance / Service | 18 | 11-16-2013 12:44 AM |
| fnkngrv's custom trailer build log | fnkngrv | Off-topic / Other Cars / Everything else Discussions | 5 | 10-12-2012 02:24 PM |
| Build Your Yaris, toyota.com | artyin | General Yaris / Vitz Discussion | 3 | 05-03-2006 05:52 PM |
