Old 05-21-2015, 03:22 AM   #1
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
If Cranky is autocrossing, yea, he is definitely getting in the ABS zone sometimes. Everyday driving, probably not. Says it happens at crowns on parking lots, so its probably an autocross event.
-Derrick-
Old 05-21-2015, 06:33 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by ArmstrongRacing View Post
Is the check valve still in your brake booster line? And in the correct flow direction?
If there's a check valve, it's not in the section that I replaced. The Blitz kit only extends the connection from the brake booster to the intake plenum, which is just a hose.
Originally Posted by CoryM View Post
Your guess of a blocked vacuum line is probably correct. It's possible to get some erratic pedal effort due to a failing booster, but that's usually minor. Silly question, but is your vacuum line connected before the blower? Otherwise if you are making boost your vacuum stuff will not be working well .
Abs is likely not doing anything because you aren't able to brake hard enough to cause lock-up.
Yup, the vacuum line from the top of the engine block (next to the fuel rail) goes directly behind the TB.
Apologies, I assumed posting in the track/racing/autoX forum implied it was under performance conditions. =) Yes, it's been in parking lots.
I've recently attended a car control clinic and one of the exercises involved getting into ABS on dry, flat pavement--aka straight line braking. Got into the ABS 3 of the 4 times, so it shouldn't be an issue with "leftover" boost getting into the brake booster on rapid transition from WOT to brake. That just leads me back to the downhill slope idea...
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
Brake pedal vibrates-not rotor problem rradhay DIY / Maintenance / Service 9 11-12-2010 09:10 AM
What's with ABS? jgag123 Canada 9 01-01-2009 06:04 PM
