Old 05-26-2015, 09:26 PM   #1
M4One
Drives: 2007 Toyota Yaris Hatchback
I have the head lights on and nothing. Even tried with the high beams on. Nothing. I don't what I've done wrong Am I suppose to add a fuse?
M4One is offline   Reply With Quote
Old 05-26-2015, 09:29 PM   #2
You should check to make sure it is present in the under-dash fuse panel (FR FOG). Also, I assume you added the relay?
You can bypass the switch assembly using a jumper wire (or paperclip) between the yellow and beige wires. If the relay and fuse are installed you should hear the relay click when you jump those two or flip the switch. If you do, then everything inside the car is fine and the issue is under the hood.
DC header, AEM cai and MI lightweight crank pulley install aspro Performance Modifications 7 09-02-2014 06:57 AM
2007 Sedan HU, Amp, Speaker install Crackerballer In Car Entertainment + Electronics (audio / video / alarm) 15 11-14-2011 07:47 PM
Yaris SR - JL Audio Install + Sound Deadening (Progress Thread) Nips In Car Entertainment + Electronics (audio / video / alarm) 8 03-18-2011 12:42 AM
