Old 05-29-2015, 06:34 PM   #1
The problem is that the plastic gear assembly is still on the shaft for the crank. That whole black chunk needs to come off to mount the crank. also, the door hole around the crank was widened, so you are going to have a large gap, unless you replace the entire door cards.
Yaris Power window switch fires auxmike General Yaris / Vitz Discussion 7 06-21-2012 02:41 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
HELP! Removing manual window crank Astroman DIY / Maintenance / Service 8 05-26-2009 08:46 PM
from manual to power windows/locks. TickleTimeTim Cosmetic Modifications (Exterior/Interior) 3 04-27-2009 12:28 AM
