![]() Drives: 2007 yaris sedan Join Date: Jul 2011
I did slide a clear cover off and see two fusible links. I took the battery out so I could get a better look at it and all seemed fine. when inspecting the cable end I felt as tho the white wire coming off the battery cable terminal fuse block felt funny I would have ohm it but couldn't figure out were it went.
#2 | |
With the other three black ones that come off of the positive terminal, they are all connected to the 120A ALT fuse on the terminal. One goes straight to the alternator, the second to another group of fuses (HTR SUB2, EPS, ABS, HTR, ABS2, HTR SUB1, and RDI), and the third to the under dash fuse panel.
