Old 06-12-2015, 06:24 PM   #1
tmontague
tmontague's Avatar
sooo, after all this battery chat I went to start my car after work today and low and behold I hear the typical low battery starter buzz. It sounded a little more faint than the typical buzz so I wasn't sure what it was.
I was able to get it started (although it cranked slowly) I'm assuming the fuel from each unsuccessful start primed it enough to start on a very slow crank. After driving 10 mins I turned off the car and then started it again with no issue or slow crank. After a 30 mins I went to start the car and it again buzzed and then slow cranked.
Replaced the battery and now it crank faster than it ever has in about 2 years. $120 w/ taxes for the same size battery from Canadian Tire after the $20 I received from returning the original.
I can't complain the OEM battery got me through 7 and a half years and some nasty winters and never left me stranded. Too bad you can't purchase the OEM batteries for the same amount as an aftermarket...
Old 06-12-2015, 09:32 PM   #2
Hi mpg
Drives: 2010 3dr Yaris
I'm at 206k miles on my original battery. No problems, I put on 40k a year, and when it dies, I will go with a Optima.
Hi mpg is offline   Reply With Quote
Old 06-13-2015, 04:24 PM   #3
RedRide
RedRide's Avatar
I had an Optima (red top) in my 02 Celica and it was great.....particularity its cold cranking power compared to the stock battery.
BTW, the Optima and the Auto Zone's "Duralast" battery are both made by the same company ..."Johnson Controls" and the" Duralast" is reported to be very good also. The Optima is better of course.
Old 09-27-2016, 09:55 AM   #4
snowsquirrel
Drives: 2008 Yaris 5dr LB
Hey tmontague,
so what size battery did you get from CT? did you try the dealership? wonder what brand they carry if not Pan or FB?
snowsquirrel is offline   Reply With Quote
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
Checking Battery bad DIY / Maintenance / Service 7 07-14-2014 03:10 PM
Battery keeps going dead Outdoorsman In Car Entertainment + Electronics (audio / video / alarm) 6 09-09-2013 05:43 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 10:34 PM
OEM Parts hatchbackkid82 Items for Sale by private party 30 12-17-2009 11:08 AM
