Old 06-17-2015, 10:04 AM   #1
Ranger SVO
Drives: 2010 Yaris
Passenger Air Bag Light Not On
I have a question, I just noticed that the Passenger side air bag lights are not on.
The Passenger AirBag OFF and the Passenger AirBag ON lights are not.
The air bag diagnostic light on the dash is off, so I'm guessing that everything is working, but it would be nice if the lights would be on.
What should I check?
The moving power of mathematical invention is not reasoning but imagination.
Augustus de Morgan
Truth does not change because it is, or is not, believed by a majority of the people.
Giordano Bruno
Ranger SVO is offline   Reply With Quote
Old 06-17-2015, 10:43 AM   #2
nookandcrannycar
If I'm understanding your explanation correctly, everything is working correctly. In the past, I had a similar feeling because of the labeling. After reading en explanation on some past thread as it came along in real time, I remember feeling that the labeling seemed counter intuitive. IIRC, lighting will change if you have enough weight on the front passenger seat that the system thinks there is a person sitting on the seat. CTScott is the expert on this, as he developed an aftermarket bypass module for the front passenger seat/airbag interaction.
Old 06-17-2015, 10:43 AM   #3
Ranger SVO
Drives: 2010 Yaris
Thanks for your response,
OK, I just found this and it describes my car exactly
http://www.yarisworld.com/forums/showthread.php?t=31124
How do I fix this??
Augustus de Morgan
Giordano Bruno
Old 06-17-2015, 10:59 AM   #4
nookandcrannycar
The way I'm understanding the thread you linked to, CTScott is describing a likely explanation, and both Debby and ersheff are agreeing and giving their experiences as examples. Are you experiencing ersheff's phenomenon, except without any weight being placed on the passenger seat at all (different from ersheff's bag and Debby's container of milk) ?
Old 06-17-2015, 11:46 AM   #5
Ranger SVO
Drives: 2010 Yaris
OK, when I sit in the passenger seat, the Airbag ON light illuminates and the seat belt light flashes.
When I get out of the seat, no lights are on. (both the AirBag OFF and AirBag ON lights are off)
When I put two One gallon jugs of water in the seat, the seat belt light flashes, both the AirBag OFF and AirBag ON lights are off
Augustus de Morgan
Giordano Bruno
Old 06-17-2015, 09:03 PM   #6
nookandcrannycar
The sensor can detect a shift in weight (per CTScott), so I'd think you might be getting a different response than Debby did because the jug likely isn't in the exact same place in both instances.
Old 06-17-2015, 10:30 PM   #7
That is possible. Also, the calibration of the module to the sensors can cause two cars to behave differently.
Old 06-17-2015, 01:41 PM   #8
shepd
Drives: 2007 Yaris 5 door RS
Here's the truth table for that indicator:
Condition / ON Indicator / OFF Indicator
Vacant / OFF / OFF
Adult is seated / ON / OFF
Child is seated / OFF / ON
Child restraint system is set / OFF / ON
Front passenger occupant classification system failure / OFF / ON
Yours appears to operate correctly. OFF / OFF means no human detected by the seat. ON / OFF means it found an adult in the seat. Airbag OFF actually means "Person detected in seat and airbag will not deploy", rather than "Airbag will not deploy". No lights at all mean "Nobody is occupying that seat, airbag will not deploy".
Old 06-17-2015, 03:17 PM   #9
Ranger SVO
Drives: 2010 Yaris
Vacant / OFF / OFF
Thanks, I guess that makes sense. Thank you
Augustus de Morgan
Giordano Bruno
Old 06-17-2015, 09:04 PM   #10
nookandcrannycar
Vacant / OFF / OFF
Electrical Problems PS,A/C,RADIO,SPEEDOMETER,SIGNALS,AIR BAG LIGHT ON, ALTERNATOR toystory DIY / Maintenance / Service 43 04-17-2021 04:54 AM
2005 yaris vvt air bag light Lewissmith33 DIY / Maintenance / Service 1 10-26-2012 01:55 PM
AIR BAG SENSOR FOR FRENCH MANUFACTURED VERSION OF 2005 YARIS T3 edgarinuk DIY / Maintenance / Service 7 09-11-2012 01:36 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
