Old 06-24-2015, 11:51 PM   #5
CoryM
Drives: 2009 5-door, 5-speed
Originally Posted by werther View Post
First off thank you all for the suggestions/opinions. I appreciate it.
So I went back to the dealership/service center. We sat with the manager and the technician.
Basically they went step-wise changing parts that trigger P0128. As follows:
- Tstat
- Cooling system
- ECT sensor
Next in line...
The WIRE HARNESS
They walk me through those steps. Yes, CoryM that is what they are planning to do.
They showed me the factory white page of the wire and it is a hell of a job for such an error that a priori seems so innocent, I mean, it isn't that the car overheats or can't run!
Anyways... we reached a deal for parts cost only which I seemed fair.
This made me wonder of you guys driving your Yaris for over 100k miles... how much of this stuff you have to (or I will have to) go though only to keep this beautiful car.
Wiring harness issues are not common with this car, but can happen on any. Especially if the car has been in a crash or had work done where the harness may not have been correctly routed/secured. Just throwing it out there, but in that entire engine harness, there are only 2 wires that go to the sensor from the computer. In some cases, I have just replaced the required wires, and routed the new ones on the outside of the harness. It's not ideal, but is much more cost effective. No question that replacing the harness is better, but if the two wires are done correctly you will still correct the issue.
Cheers.
2007 Yaris and Service Engine Soon takissd DIY / Maintenance / Service 8 06-02-2011 03:18 PM
Previa service + yaris update jetlag 5000 General Yaris / Vitz Discussion 0 10-17-2010 02:53 AM
I hate cable service providers. Altitude Off-topic / Other Cars / Everything else Discussions 27 09-12-2010 09:09 AM
service maintance light io3 Yaris TS Talk 11 09-22-2009 03:03 PM
Why does 15000 service cost so much more than 5000 and 10000 mile service? monyaris DIY / Maintenance / Service 7 06-25-2009 07:12 PM
