Old 06-27-2015, 02:27 PM   #2
First click is the closest to published fuel capacity.
If you fill to first click every time, and properly divide distance traveled by fuel top up amount, there is no way your calculations can be off. The only variable in the equation would be the sensitivity of the shut off on the gas pumps. That is why for truly accurate calculations it is recommended to, as much as possible, use the same station, same pump whenever filling the tank.
Total KM in a full tank petrol HDTechVideo Fuel Economy Forum 1 01-23-2015 11:11 PM
90 miles on full tank and still have full bars.. vitzbitz69 DIY / Maintenance / Service 4 03-06-2014 12:59 PM
DIY - Removing the gas tank from under the car (to access the fuel filter, etc.) CTScott DIY / Maintenance / Service 1 08-21-2013 04:57 PM
