![]() Drives: 07 yaris sedan Join Date: Apr 2009
I'm going to order a new fan switch. Only 30 bucks. Sorry, last post with jump wires was too technical. I might just run a switch and inline fuse direct from the battery at this point. Only need high speed on the fan. Is this possible?
I don't believe it is the switch, as a bad switch should not make the wires at the fan heat up.
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
It is possible, but you would want to run it from IGN instead so you never leave fan on overnight. If the wiring to the fan motor is good, it could be done fairly easily. It's always best to fix the problem when possible though, rather than bypass it.
| Passenger airbag light on making turn signals and cabin fan not blowing? | thatbryanguy | General Yaris / Vitz Discussion | 17 | 08-16-2024 11:23 AM |
| Heater fuse keeps blowing, interior fan is dead. | phyrefighterjay | DIY / Maintenance / Service | 10 | 07-19-2015 08:18 AM |
| dead fan motor | dferguson2 | General Yaris / Vitz Discussion | 10 | 07-22-2012 02:18 PM |
| blowing ear drums and poping fuses | BlueFlash | Southwest | 5 | 05-29-2007 08:10 PM |
