Old 07-24-2015, 08:48 PM   #1
It is likely the aux port. Besides passing the audio signals it triggers a switch within the jack that tells the head unit to enable aux mode.
Old 07-25-2015, 01:25 AM   #2
MoneyT8
Drives: White Yaris Sedan
Any suggestions on fixing this issue? Is this a known issue with the Yaris?
MoneyT8 is offline   Reply With Quote
Old 07-25-2015, 06:34 AM   #3
Not a common issue, but if you plug and unplug frequently, you simple wear out the contacts in the jack. The simplest fix is replacing the jack.
Old 07-25-2015, 09:18 AM   #4
MoneyT8
Thank you, do you know the part #? It's strange because it was my first time using it I guess the previous owner used the hell out of it. Thank again .
Old 07-26-2015, 01:47 PM   #5
bairjo
I'm at work right now, otherwise I would go out to my car to see if this makes any difference....doe the audio source need to be turned on in order to trigger that switch or does the fact that a plug is inserted and making contact do the trick?
bairjo is offline   Reply With Quote
Old 07-26-2015, 04:46 PM   #6
No. Plugging the plug in triggers a switch within the jack that closes a circuit to tell the head unit that an aux source is present.
Old 07-27-2015, 03:35 PM   #7
bairjo
ok...now I know....thank you. I can just remember a time when I was fumbling trying to flip that little cover up and plug the aux wire in with the one hand until the aux function worked. I couldn't remember whether the source was on or off when I finally landed the plug in the hole...that little flipper cover is a pain in the butt when you are driving...
DIY: Adding AUX input to 2006 french Yaris - W58824 sven337 DIY / Maintenance / Service 4 04-17-2022 12:59 PM
DIY: Aux Input Jack Adapter TinyGiant DIY / Maintenance / Service 11 11-10-2012 05:33 AM
Aux Input Trouble boeduur In Car Entertainment + Electronics (audio / video / alarm) 4 04-07-2011 11:44 AM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
