Old 07-25-2015, 01:25 AM   #1
MoneyT8
Drives: White Yaris Sedan
It is likely the aux port. Besides passing the audio signals it triggers a switch within the jack that tells the head unit to enable aux mode.
Any suggestions on fixing this issue? Is this a known issue with the Yaris?
MoneyT8 is offline   Reply With Quote
Old 07-25-2015, 06:34 AM   #2
Not a common issue, but if you plug and unplug frequently, you simple wear out the contacts in the jack. The simplest fix is replacing the jack.
Old 07-25-2015, 09:18 AM   #3
MoneyT8
Thank you, do you know the part #? It's strange because it was my first time using it I guess the previous owner used the hell out of it. Thank again .
DIY: Adding AUX input to 2006 french Yaris - W58824 sven337 DIY / Maintenance / Service 4 04-17-2022 12:59 PM
DIY: Aux Input Jack Adapter TinyGiant DIY / Maintenance / Service 11 11-10-2012 05:33 AM
Aux Input Trouble boeduur In Car Entertainment + Electronics (audio / video / alarm) 4 04-07-2011 11:44 AM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
