Old 07-28-2015, 05:59 PM   #1
scod4025
Drives: 12 LE 5d HB 1nz-fe Automatic
So heard back from Holinger and with a little discussion decided that the SF will work just fine on the Yaris unless you plan on out putting more that 270 ft.lbs of torque to it which isn't in the plan only issue is was thinking maybe it would top out near 15k but was slightly wrong going to run me about 20k plus S/H and accessories which is going to push this back quite a bit but will still stay in the hunt for a sequential gear box maybe find one a little bit cheaper else where but will keep you guys up to date
scod4025 is offline   Reply With Quote
Southern Streets Presents Kami Speed Invasion 1.5 Southeast 34 09-08-2013 10:17 AM
The most economical speed for the Yaris. Ilovemyyaris Fuel Economy Forum 3 03-19-2012 11:33 AM
LTA Land Speed Races Harvest Edition 2011 fnkngrv Off-topic / Other Cars / Everything else Discussions 10 01-12-2012 10:06 PM
Cold Idle Speed Question... cpnnz DIY / Maintenance / Service 9 11-04-2009 05:31 PM
