Old 08-01-2015, 05:02 PM   #1
SeanD
Drives: 2008 Yaris Base Manual Hatchba
That definitely confirms non-OEM. No Yaris ever had a hatch release and definitely not an electronic one.
Now you need to poke around under the dash to find out what brand/model of keyless entry system is installed, so you can order a replacement remote for it.
OK, chalk that up to bad memory and confusing car models. No electronic hatch release - verified.
So, why won't it accept these new remotes? The fact that the key in, key out .. close and open ... routine goes into program mode and confirms with door lock/unlock seems to me to confirm Factory. We got it new from the dealer and it came with it.
Thanks for your response.
SeanD is offline   Reply With Quote
Old 08-01-2015, 09:22 PM   #2
Have you tried rewrite, instead of add mode?
Old 08-01-2015, 10:20 PM   #3
SeanD
Thanks again for your responses CT. I did get a chance to try REWRITE. I got to double lock/unlock confirmation and then it just does not seem to "hear" my remote.
I had a thought ... what fuse is the remote receiver on? That would explain my symptoms exactly. I don't think she has any blown fuses, I was just trying to figure out what would produce this situation. Of course dead receiver module is another choice.
Old 08-01-2015, 10:36 PM   #4
The door control receiver is on the DOME fuse. If that one was bad you wouldn't have a working radio or working dome lights, so I would not think that it is the issue. I is quite possible that something is wrong with the receiver.
With the Toyota Techstream diagnostics tool it would be possible to do significant troubleshooting.
Old 08-02-2015, 11:38 AM   #5
SeanD
OK, that is good news. I have ordered the laptop software and already have received the cable. I expect the software any day now. I may be asking advice on diagnostics very soon.
Thank you for your patients and for helping me track this down.
Sean
Tags
4 button, fob, keyless entry, keyless remote
Yaris Key fob wont lock my doors! Treeny DIY / Maintenance / Service 3 03-29-2012 07:27 AM
Yaris aftermarket push start button installed marschall DIY / Maintenance / Service 2 08-14-2011 05:48 PM
toyota yaris factory romram General Yaris / Vitz Discussion 15 07-14-2011 06:36 AM
