![]() ![]() Drives: 2015 yaris le Join Date: Feb 2015
The yaris has somewhat of a naturally funky acting tranmission. We bought a lease return last year from a private dealer with around 122k, and I put around 30k on it. When cold, it takes a bit longer to shift to 3rd from second. Since it only has 4 gears, I assume that it could be causing somewhat of a problem. When I go uphill or downhill, I find myself jumping between 3 and 4 alot. I can even manually change it many times from 3 to 4.
A few months ago I did a drain and fill with full synthetic atf at around 50k. No difference, and there wasnt metal shavings or anything. I believe it's just the design. You shouldnt worry to much about it. If you get high or low revs, just give it a little more or less gas or change it manually |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| Toyota Yaris T3 1.4l D-4D Engine Failure | justborg@gmail.com | DIY / Maintenance / Service | 0 | 04-20-2013 09:12 AM |
| Engine noise and Oil Lamp on | bieniman | DIY / Maintenance / Service | 21 | 12-12-2010 11:47 PM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
| Free gas for any vehicle. | ketel0ne | General Yaris / Vitz Discussion | 4 | 09-19-2006 08:07 AM |
