conundrum562
Drives: Toyota Yaris 2007 Type S Join Date: Jun 2010
Did you guys get an extra pulley with the Blitz kit you guys have? Supposedly the Vitz version comes with it, mine didn't come with a pulley and the Bando 4PK1695 belt is too long.
Help...
--------------------------------------------------------------- BLITZ S/C|MICRO-IMAGE CRANK PULLEY|NST ALT;WATER PUMP PULLEY|BLITZ SUS SHORT RAM;HEADERS;AXLE-BACK EXHAUST|2.25 PIPING|1ZZ INJECTORS|OPTIMA YELLOW-TOP|GTSPEC FRONT STRUT;MID LOWER CHASSIS;4 PNT FRNT LOWER BRACE|WHITELINE REAR SWAY;BUSHINGS|TANABE FRNT SWAY|TRD LOWERING SPRINGS/SHOCKS|R1 CONCEPT DRILLED & SLOTTED ROTORS|EBC GREEN PADS|THROTTLE SPACER|XTREME PERFORMANCE CHIP MOD
No. 1695 would only be for the Vitz setup. For the Yaris with A/C, 1675 is the correct length. 1675 is generally not available as a 4PK1675, so you buy a 8PK1675 and slit it between the center ribs, thereby ending up with 2 belts for the price of one.
#3 | |
conundrum562
The belt was cut as advised and works perfectly! Haven't turned on the car yet as we are now in the process of the electrical portion. Did you directly connect the red wire to the battery with a fuse?
| yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 01:05 AM |
| Seat belt buzzer is silenced | billk | General Yaris / Vitz Discussion | 48 | 10-30-2013 09:58 AM |
| Water pump belt and pulley - replaced at 36,000mi | cleong | DIY / Maintenance / Service | 3 | 03-06-2009 12:12 AM |
| Underdrive Pulley Belt | ruimond | Performance Modifications | 11 | 02-14-2009 09:05 AM |
| The Accessory belt? | N9QGS | DIY / Maintenance / Service | 4 | 02-12-2009 11:05 PM |
