Old 08-14-2015, 08:53 PM   #1
Originally Posted by AzianCuz View Post
Did you guys get an extra pulley with the Blitz kit you guys have? Supposedly the Vitz version comes with it, mine didn't come with a pulley and the Bando 4PK1695 belt is too long.
Help...
No. 1695 would only be for the Vitz setup. For the Yaris with A/C, 1675 is the correct length. 1675 is generally not available as a 4PK1675, so you buy a 8PK1675 and slit it between the center ribs, thereby ending up with 2 belts for the price of one.
Old 08-17-2015, 11:49 AM   #2
AzianCuz
conundrum562
AzianCuz's Avatar
Drives: Toyota Yaris 2007 Type S
Send a message via AIM to AzianCuz
Thumbs up 8PK1675 - Belt
CTScott:
The belt was cut as advised and works perfectly! Haven't turned on the car yet as we are now in the process of the electrical portion. Did you directly connect the red wire to the battery with a fuse?
BLITZ S/C|MICRO-IMAGE CRANK PULLEY|NST ALT;WATER PUMP PULLEY|BLITZ SUS SHORT RAM;HEADERS;AXLE-BACK EXHAUST|2.25 PIPING|1ZZ INJECTORS|OPTIMA YELLOW-TOP|GTSPEC FRONT STRUT;MID LOWER CHASSIS;4 PNT FRNT LOWER BRACE|WHITELINE REAR SWAY;BUSHINGS|TANABE FRNT SWAY|TRD LOWERING SPRINGS/SHOCKS|R1 CONCEPT DRILLED & SLOTTED ROTORS|EBC GREEN PADS|THROTTLE SPACER|XTREME PERFORMANCE CHIP MOD
AzianCuz is offline   Reply With Quote
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Seat belt buzzer is silenced billk General Yaris / Vitz Discussion 48 10-30-2013 09:58 AM
Water pump belt and pulley - replaced at 36,000mi cleong DIY / Maintenance / Service 3 03-06-2009 12:12 AM
Underdrive Pulley Belt ruimond Performance Modifications 11 02-14-2009 09:05 AM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
