Old 08-15-2015, 12:30 AM   #1
bairjo
Originally Posted by something View Post
If you turn the key and all you hear is a loud noise like someone put a card in the spokes of a bicycle wheel (but way louder), and it sounds almost like a grinding noise, and the engine isn't even thinking about turning over, and you are worried about wrecking your car by continuing to turn the key... here is what you should do: GO TO LORDCO, buy a new battery, remove old battery, replace with new battery. Turn key... engine will start. Please don't get your car towed to a mechanic for no reason. This could save you $200 or more. (Even if the indicator on your battery is shining blue you should do this since the indicators often don't work. i.e. don't assume your battery is fine if the indicator is blue!)
well that was good advice...to bad he could have used it six years ago. probably on his 3rd battery by now. JK...Welcome to the forum...we need all the advice we can get!
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Yaris does not start jake002 DIY / Maintenance / Service 21 01-05-2010 08:53 AM
Transmission designed for 10-15 min cold start delay Ironwill5 DIY / Maintenance / Service 29 12-03-2009 08:08 PM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
Viper Remote Start goku87 In Car Entertainment + Electronics (audio / video / alarm) 4 12-13-2008 05:06 AM
