#19 | |
![]() ![]() ![]() ![]() ![]() Drives: '15 Yaris SE 5MT Join Date: Jun 2014
#20 | |
In respect to the black tops, my bro in law has a black hood, roof and trunk on his BMW 3 series. Looks really good. |
#21 |
![]() Drives: Black 2012 SE manual Join Date: Feb 2013
Really nice and stands out in white... you'll like the somewhat tauter dynamics of the SE.
He he - now that you've driven the car a few miles, just picture how you would have felt if you had ordered an automatic transmission : \ May I suggest peeling the dealer adhesive label on the trunk while it's fresh ? Congrats... |
#22 |
#23 | |
#24 |
From what I read on the internet, you just heat it up with a blow-dryer (or the blazing hot AZ sun) and then take something like a drivers license to get the edge started, and then just peel it up.
#25 | |
Maneuvering in a tight space is tricky however! Perhaps some version of this can be applied to a MT.
#26 |
I always peel that sticker off the day I get the car. Sometimes I wonder if I'd be too mean if I peeled it off on the lot before leaving. Lol
Sent from my A0001 using Tapatalk |
#27 | |
' stickers. I guess I've just been lucky.
#28 |
The dealer one on my Yaris was some sort of cheap die-cut rubbery clear plastic with imprints of letters/graphics on them - not the type that I am used to seeing. It peeled up pretty easy. The ones on some of my older cars were made of pin-stripping type material and once they baked on in the sun, they were a nightmare to remove, since they broke apart so easily into little pieces if you tried to peel it up.
#29 | |
) and Phoenix has got to be #1 for the consistently highest Summer heat index, followed by Houston, DFW, and San Antonio battling each other pretty evenly. I figured what worked for you might work for me. I let the car bake in the sun for about three hours. I then did two important time dependent errands...making sure I parked in the sun. I then sat down behind the car and scraped with my nail I had recently trimmed. The last T and the only A in TOYOTA came off very easily. I was so encouraged, I scraped off the rest of the letters very quickly. The letters came off easily, but I did this so fast, gummy residue was stiill left behind. I tried spit and a cloth. Didn't help. I took the small cloth and walked to a nearby business and rinsed and soked the small cloth. I came back and wiped again. Still didn't help. I decided to go to Fred Haas Toyota and ask someone there. I drove up (a half hour before service and parts close) and they had just finished putting cones up so no more people could get in line. I parked and walked into the service writer's building. One of the service writers suggested using any road tar, etc removal product from a chain auto parts store...and after removal. put a bit of wax on that area. I went to the parts department to see if they had a TRD plate frame (wanted to get rid of the one with the same Florida dealer name as the lettering I just removed). They didn't have a TRD plate frame, but they gave me a 2 pack of metal Fred Haas frames I decided to do a bit more research on the internet re paint friendly 'gummy residue' solutions. Eventually I found a detailing article that claimed either Windex or WD-40 would work and not damage the paint. I was about a block away from a Wal-Mart, so I decided to see if the 'Windex' in the trough at their gas station was strong enough. Nope, not strong enough...didn't help. I went home and grabbed some Windex. That worked. All the residue and the 'dirt' on top of the residue disappeared. Later, in different light, I saw something I hadn't seen before. The best way to describe it is that the stenciling baked on an EXTREMELY faint clear hologram of the previous lettering. It can only be seen at a distance of 18" or less, and only in certain types of light and at very limited angles. I'm very pleased with the results....won't 'nag' at me at all Perhaps my story will help someone else ( ) re removing such lettering.
#30 |
^^^^^ Obviously, this isn't an actual hologram...that's just the best way to describe the appearance.
#31 |
I went out this morning around 8am and did a couple things to my Yaris. It is supposed to get up to 113+ today here in Phoenix, and it was hot as hell even at that time in the morning.
![]() I installed the polished stainless-steel exhaust tip, the VVT-i badge, and cleaned the dealer sticker gunk off the lower hatch lid. I am going to try and get up around 5:30am tomorrow and wash/wax/detail her, since she will need a good coat of quality wax on her in this weather. Here are some pics of the work thus far: ![]() ![]() ![]() ![]() In case anyone is interested: The Toyota Part Number for the VVT-i badge is 75443-06151. It is quality metal construction with the same adhesive backing as what is on the OEM Yaris and SE badge. The exhaust tip was a great fit on the 2015 Yaris, and is a 'Superior 28-6201 2 1/2" x 6" Stainless Steel, Slant Bolt-On Exhaust Tip' that I found on Amazon for around $22. The intake is 2" and the outlet is 2.5" - just the right size IMO. Oh, and just for the fun of it, I put this decal on my upper passenger front window. It is small, but I like it.
#32 |
Also put a small white TRD decal on the inside gearbox. Sorry for the fuzzy, sun-drenched pic...
#33 |
#34 |
![]() ![]() ![]() Drives: 2011 3dr LB Polar White Join Date: Apr 2011
Have you used the cup holders yet? I'm curious how they might hold a bottle of water, or in my usual case a Venti Starbucks drink. Not crazy about the placement, but if they work well I'd be happy.
#35 | |
I ordered one of the OEM Toyota "lid/hinged ashtray cups" to fit into the rear cup holder between the seats, as a change holder. I will also test-fit it to the cup holder in the door and the dual ones in front of the gear box - and if it fits in those locations also I may order at least one more for extra concealed/removeable storage (one dedicated to pennies only at least, since I prefer to keep those separate and roll them into 50 cent rolls towards gas-money as they build up). - |
#36 |
I normally work 7 days per week (56 hours/week, 8 per day), but decided I'm going to start taking one Sunday off every month in order to wash/wax/detail my Yaris. Gotta keep her protected as much as I can from the brutal Arizona sun/heat.
![]() I got up at 6am this morning and managed to get her fully wash/waxed/detailed, inside and out, but I tend to be a pokey cleaner just like I am a pokey "speed limit" type driver most of the time, and the sun was killing me by the end around noon or so. I am also sort of OCD about details, so washing/waxing/detailing takes me longer than it should. But on the bright side, it gave me a chance to examine literally every aspect of my Yaris and get to know it better. The more I drive this car, the happier I am with my choice to get it. The only must-do things I have left to do ASAP is install a license plate frame/protective backing when I am able to get my tag, and then get the windows tinted/shielded appropriately (including some street-legal 3M Crystalline protective tint for the front windshield). I also ordered a 'Covercraft UV11265SV UVS100 Silver Heat Shield' (custom fit for 2012+ Yaris front windshield) to help prevent the sun/heat from coming through that monster-sized front windshield when it is parked at work, etc.. The dark cloth seats in the SE heat up pretty toasty when the sun is hitting them directly through the windows. I'm putting together a pretty comprehensive list of likes and dislikes about my 2015 Yaris SE and will post it later this week, after I drive it for another week to work. Interesting enough, some of my initial observations about the car, such as the sensitive gas-pedal, are non-issues now that I am accustomed to it. I was just used to having a heavier foot with my 2000 Accord and the older cable-driven accelerator mechanics, so it was a shock the first time I drove my 2015 Yaris. - Last edited by Kalispel; 08-16-2015 at 08:29 PM. |
