![]() ![]() Drives: 2015 yaris le Join Date: Feb 2015
Suspension sounds? Sway Bar Bushings?
For the past while, I notice creaking sounds going over bumps. I checked control arms, bushings, tie rod, shocks etc, didnt notice anything. The only possible thing left would be the sway bar bushings. How do you get those off? They are really inaccessible? I was trying to grease the insides and couldnt even get a bolt loose. I used a light impact, and a breaker bar on the bottom and nothing. I soaked it with atf, and it still doesnt open. I greased the sides with lithium grease, still not much has changed.
Any advice? |
Get someone to rock the car side to side (by pushing on the roof) while you reach under the car to feel for the creaky noise.
I'm hoping i'm wrong but I think the only way to access the bushings is by dropping the sub frame. I don't see a way to access all 4 bolts by leaving the sub frame installed.
How many km's on your car? Check the strut mount and bearings.
| Tags |
| bushing, control arm, suspension, sway bar, yaris |
| Which Rear Sway Bar?? | Airswoosh1 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 02-23-2013 04:49 AM |
| TRD rear sway bar brackets and bushings | MasterShake | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 23 | 10-22-2012 10:26 PM |
| My Ultra Racing rear sway bar install | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 49 | 03-03-2011 03:08 AM |
| sway bar... Toyota dealers must be insane! | RedRide | General Yaris / Vitz Discussion | 10 | 07-24-2009 04:39 AM |
| Sway bar and struts | DOMAV | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 07-17-2009 03:26 AM |
