Old 09-05-2015, 01:38 AM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
DI engines will go much longer without issues if people would actually DRIVE them in most in stances . It is no different that multiport or ither variants. You need to put them up into their higher rpm ranges every so often to burn the garbage out. The problem is that most folks don't do that.
Sent from my SCH-I545 using Tapatalk
Old 09-05-2015, 06:20 PM   #2
nookandcrannycar
DI engines will go much longer without issues if people would actually DRIVE them in most in stances . It is no different that multiport or ither variants. You need to put them up into their highe rom ranges every so often to burn the garbage out. The problem is that most folks don't do that.
Sounds as though I need to gain a temporary lead foot .
Old 09-05-2015, 06:27 PM   #3
fnkngrv
fnkngrv's Avatar
The boggest issue really is that if you are always just nursing the gas you will get in trouble quicker since DI doesn't have the ability to wash fuel over the valves.
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
2009 Sedan Auto Transmission Oil Change DIY 09sedan DIY / Maintenance / Service 37 01-07-2018 02:09 PM
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
instrument cluster-TACH "S" model Lewis DIY / Maintenance / Service 65 11-15-2009 02:19 AM
