Old 09-08-2015, 08:03 PM   #1
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
The speakers will not get 100watts at all time. It is not linear, as in max vol. = 100 watts, and 1/2 volume = 50watts.
It is little tough. Because if you are sending a particular hertz to a woofer and it hits real hard you can have a peak watt moment happpen. This mostly concerns subwoofers, though.
Let me ask you this: why are you asking about this? What is you goal/concern?
brushforhire is offline   Reply With Quote
Old 09-09-2015, 12:32 AM   #2
nehal.hasnain
Drives: Toyota Vitz 2009
The reason I am asking this is because I am planning to get an amplifier without a gain control option. Just like Pioneer GM-D1004. It's small, fits right behind the dash. I haven't fixed my mind yet on this. Pioneer GM-D1004 is just an example.
Anyway, this particular pioneer amplifier has 2 suitable option for DB6501:
Nominal Power (RMS) Output at 4 Ohms : 45W x 4
or
Nominal Power (RMS) Output - Bridged at 4 Ohms : 90W x 2
DB6501 is 4 Ohm speaker, you already know it as you are using them.
Now, if you own a Pioneer GM-D1004 amp and want to use it with DB6501 for your front doors only (with the tweeter of course), how would you set it up ?
Will you use the 45W x 4 option and forget about other 2 channels ?
or
Will you use the Bridged 90W x 2 option and use the full power of the amplifier ?
If you want to check the full spec of this particular amp, you can visit this link : http://www.pioneerelectronics.com/PU...eries/GM-D1004
My decision is on your hand now...
nehal.hasnain is offline   Reply With Quote
Paint suggestion for rims: Anthracite or Gold? vannigo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-05-2013 11:11 AM
Lowering Springs Suggestion lambornisyoantuan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 02-07-2013 02:04 AM
Intake suggestion for 2002 stang - HELP fnkngrv Off-topic / Other Cars / Everything else Discussions 5 09-13-2011 04:40 PM
Just Got A yaris: Performance Mod Suggestion Marfulion Performance Modifications 23 03-09-2009 09:35 PM
Classifieds Suggestion RogueYaris Suggestions - Feedback - Questions 21 06-26-2007 11:14 PM
