#37 |
やりすぎだ~
You're starting to go off-topic.
If you read other threads about NST pulleys, your question would most likely have been answered. |
#38 |
I'm running 1zz injectors with my Blitz set-up. I do get a 'Too Rich' code in the winter, likely due to choke but have no CEL spring, summer or fall.
#39 |
conundrum562
Drives: Toyota Yaris 2007 Type S Join Date: Jun 2010
I hope I don't get that...
--------------------------------------------------------------- BLITZ S/C|MICRO-IMAGE CRANK PULLEY|NST ALT;WATER PUMP PULLEY|BLITZ SUS SHORT RAM;HEADERS;AXLE-BACK EXHAUST|2.25 PIPING|1ZZ INJECTORS|OPTIMA YELLOW-TOP|GTSPEC FRONT STRUT;MID LOWER CHASSIS;4 PNT FRNT LOWER BRACE|WHITELINE REAR SWAY;BUSHINGS|TANABE FRNT SWAY|TRD LOWERING SPRINGS/SHOCKS|R1 CONCEPT DRILLED & SLOTTED ROTORS|EBC GREEN PADS|THROTTLE SPACER|XTREME PERFORMANCE CHIP MOD
#40 |
not to hijack this thread but where are all of you guys sourcing your blitz S/C's from? It looks appealing to do down the road vs a T/C due t much less work required t install a S/C. I'm curious to the price and what it all comes with
#41 |
Bought mine used from an Edmonton member several years back.
#42 | |
conundrum562
Price is around $3000-$4000 now a days, depending on where you get it from. It is sourced straight from Japan, the kit is a Complete Bolt on but I found out from the installation that you need a tighter belt and added the 1zz injectors to make it run efficiently, Since I have other performance parts. But I believe the kit should run fine if you have everything stock, so far I love driving this car now and it picks up pretty quick for a Yaris ha-ha. I got my S/C from A1-Motorsports and you can negotiate pricing. Took about (3-4 Months) to get... If you are planning to go (SPEED RACER) then no the kit is not worth it, but if you're trying to get an extra boost and a better driving experience with Fuel Efficiency then yes it's worth it. In the end to each their own. But I love it!
#43 |
![]() ![]() ![]() Drives: Vitz RS Join Date: Feb 2009
I am experiencing audible ping/detonation even with 1zz injectors.
My only mods are a K&N filter in the stock air box and a Fidanza flywheel along with an aem water/meth kit. My afr at wot are around 10.5 and still I hear the audible ping/detonation. I am using ngk7 plugs and 95 octane fuel. When I check ing advance using techstream it is reading in the single digits at wot when I hear the ping/detonation. Can someone suggest what is causing this. I do have a check engine light on related to the egr thingy on the intake side of the head which was removed for the s/c install. Thanks |
#44 |
Thanks for the info Azian, looks like i'll be saving up for an S/C down the road...
#45 | |
#46 |
Wow, that's a damn good deal. The msrp in my opinion isn't worth it, but $1600 is great
#47 | |
conundrum562
Drive regular, Drive regular then VROOOMMMMMMMMMMMMMMMMMMMMMMMMMM!!!
#48 |
conundrum562
Good evening my fellow YARIS-ians,
I was wondering if anyone used this injector before? They claimed it flows at 1497cc and I am wondering if that's overkill for us? FYI I upgraded to the 1ZZ and it's working but I just want to know, if it can get me more gains I might switch over. Anyways see link below and as always appreciate all feedback: http://www.fiveomotorsport.com/fuel-...toyota/?v=3880
#49 | |
![]() ![]() Drives: 2008 Red Toyota Yaris Join Date: Mar 2011
#50 | |
conundrum562
#51 |
![]() ![]() Drives: Vitz & Supra Join Date: Jan 2011
Guys are celica 2zzge injectors recommended for sc 1nzfe or 1zz sufficient?
#52 |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
I use 1zz injectors in my Blitz'd Yaris. I run a AFe short ram intake and don't have any problems going lean with the 1zz injectors.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
