#1 | |
![]() ![]() Drives: 2010 Yaris 2dr 5spd Join Date: Jan 2015
The clutch is the worst part of the Yaris. My previous Chevy Sonic (which had an issue with grinding going into 2nd) was light years better than this Yaris clutch. |
#2 | |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
It's going to be about a month before I get a chance to do my clutch, but I am curious to see what it's going to look like ![]() Cheers. |
#3 | |
Also, sometimes when I shift into 2nd my car will jerk a little bit. Does this jerking cause clutch wear? |
#4 | |
It's definitely not great for the clutch but, so long as the clutch is in good shape to begin with, not going to kill it while she learns. If you weren't smelling burnt clutch (strong, acrid smell that lingers), you aren't wearing the clutch too badly. If she were to continue to drive like that you would see reduced clutch life but it should be fine while teaching her. It takes time to get smooth. Jerking should not cause wear of the friction surface, but will cause minute wear of the parts of the clutch that are there to absorb the shock loads. Nothing to worry about as you will always get the occasional poor shift. The clutches are designed with this in mind, and have a mechanism to deal with small shock loads. That being said, the smoother you can drive the more life you will get out of nearly every part of the car. End of the day, the Yaris is hard on clutches. You need to ride the clutch a fair bit to get going, and with the poor pedal feel it can be hard to be smooth on shifts. I wouldn't worry much as the clutches still last a long time in these cars even with that. Mine is only broken because I am subjecting it to abnormally high shock loads from the race-tires. I am a mechanic though so repairs are cheap/easy .Cheers. |
