Old 09-11-2015, 11:16 PM   #1
tmontague
tmontague's Avatar
Rears are a piece of cake. Fronts require some general knowledge of what things are what, there are many diy videos online that will help you with that.
Get the cheap Monroe's from Rockauto.com or KYB if they are the same price iif you want oem type feel. I am using Monroe now and they are great for oem feel. I also had them on when ii was running th stock springs.
Make sure you get an alignment done when you're finished. Air tools make the job much easier but are definitely not required (although a breaker bar will help!)
If it's your first time, give yourself 6-7 slow careful hrs (breaks included). If you have a friend who's done the job before it'll help you a lot, or just have a few easy to understand videos at your disposal.
Overview:
Front- Remove end link bolt attached to strut
-remove 2 bolts from knuckle and support knuckle on short bucket or stool to keep weight off of it
-loosen top bolt holding strut to body of car and pull out strut.
Use spring compressor to install spring on new strut and make sure you regrease the strut bearings with new grease.
Opposite for instal
Rears- lower rear seats and remove panel behind which gives you access to top strut bolt
-Remove lower strut bolt from strut.
-remove upper strut bolt from inside car
-pull out old strut
Opposite for new strut
It's a great diy as it saves you a ton of cash, good luck!
TW: 09-11 LB Front end conversion? NY/NJ/CT/MA enviri Items for Sale by private party 4 07-20-2013 12:01 AM
Help! Can't figure out this front end clunk over bumps. suprasb DIY / Maintenance / Service 9 07-08-2013 12:58 AM
2008 Yaris 5000 km noise in front end!! help! Jen General Yaris / Vitz Discussion 3 08-26-2009 08:29 PM
Front bra for S model Sedan? N9QGS DIY / Maintenance / Service 2 06-27-2009 08:51 PM
FT: Polar white Front End in So. Cal Walter Items for Sale by private party 33 01-16-2007 12:11 AM
