Old 09-12-2015, 12:10 AM   #1
CoryM
Drives: 2009 5-door, 5-speed
Originally Posted by attrapereves View Post
Can you explain what you mean about killing the clutch from tire slippage?
It's not the slipping that hurts it, it's the sudden traction afterwards. I daily-drive (and autoX) on DOT race tires. The raw grip of these tires is far beyond what "street" tires can do. So: going around a corner hard, gas pedal to the floor to pull the car out of the corner, the inside tire spins due to weight-transfer/body-roll, then bites very hard as the weight goes back onto the inside tire. This causes a shock to the clutch similar to if you were to let the clutch out very abruptly. This usually wears/breaks the torsional springs in the clutch disc, which are there to soak up shock loads and vibration.
It's going to be about a month before I get a chance to do my clutch, but I am curious to see what it's going to look like
Cheers.
Old 09-12-2015, 03:40 PM   #2
attrapereves
Drives: 2010 Yaris 2dr 5spd
Cheers.
Question about that. I was teaching my wife how to drive a manual today and once or twice she accidentally revved it to 4000rpm, then launched the car screeching the tires. I'm assuming this wears the clutch significantly?
Also, sometimes when I shift into 2nd my car will jerk a little bit. Does this jerking cause clutch wear?
attrapereves is offline   Reply With Quote
Old 09-12-2015, 09:01 PM   #3
CoryM
Heh. Teaching people to drive manual is fun huh?
It's definitely not great for the clutch but, so long as the clutch is in good shape to begin with, not going to kill it while she learns. If you weren't smelling burnt clutch (strong, acrid smell that lingers), you aren't wearing the clutch too badly. If she were to continue to drive like that you would see reduced clutch life but it should be fine while teaching her. It takes time to get smooth.
Jerking should not cause wear of the friction surface, but will cause minute wear of the parts of the clutch that are there to absorb the shock loads. Nothing to worry about as you will always get the occasional poor shift. The clutches are designed with this in mind, and have a mechanism to deal with small shock loads. That being said, the smoother you can drive the more life you will get out of nearly every part of the car.
End of the day, the Yaris is hard on clutches. You need to ride the clutch a fair bit to get going, and with the poor pedal feel it can be hard to be smooth on shifts. I wouldn't worry much as the clutches still last a long time in these cars even with that. Mine is only broken because I am subjecting it to abnormally high shock loads from the race-tires. I am a mechanic though so repairs are cheap/easy .
Cheers.
